My audio CDs won't rip
  • colinatt
    • May 2009
    I have just updated dBpoweramp and I find now that no audio cds however new and pristine will either rip or play. I have carefully configured secure ripping and have Accurate rip running, but all that happens is that Track 1 runs for maybe half a minute then reports an error (damaged disk) quickly followed by errors on all other tracks. Interestingly, at the same time I have to report that no available software player will play beyond half a minute of a track (Windows media player, Quicktime).
    I thought this maybe a fault with my DVD writer drive, so I bought a new one - with the same results!
    Any ideas what I'm doing wrong?
    • 43929
    Re: My audio CDs won't rip
    Clear dBpoweramp and its settings:
    Re-install, then try ripping straight away on the same settings as default.
    • colinatt
      • May 2009
      Thanks, Spoon for prompt reply. I've done exactly as you suggest, with the same results as before - errors down all 12 tracks and the message for each "unable to read CD, check CD disk (frame LBA 7696 ripping 26 frames track end LBA 17823)".
      Anything else I can try?
        • 43929
        CD Ripper >> Options >> Communication to Windows Internal
        • colinatt
          • May 2009
          Thanks again. I've done this - gone to Communication to Windows Internal, closed and restarted CD Ripper - and the result is the same as before. Very similar error message.
          Is it possible that some sort of DRM program has got into my machine which blocks any form of copying, even playing?
            • 43929
            Yes very possible.
            • colinatt
              • May 2009
              So. No answers then. I would have liked to carry on using poweramp - excellent if it works. If I ever find an answer I'll let the forum know.
              • Stockdoc
                • May 2009
                I have just encountered pretty much the same problem. I have succesfully ripped about 80 CDs when suddenly the db won't rip. The first track starts to rip about 5 secs then followed by an error for all remaining tracks.
                I can rip in iTunes without any problems so I guess this must be a db problem? I have reistalled etc, any advice?
                Henrik
                • Wayne
                  • Aug 2002
                  • 1252
                  What version of windows are you using? What are your Ripper setings? Can you rip the other tracks individually?
                    • 43929
                    Have you tried?:
                    • Stockdoc
                      • May 2009
                      Thanks Spoon, it's up and running again!
