Compilation tag not being passed using [Multi Encoder]
  • brianblank
    • Apr 2007
    I am using the following naming convention:
    [IFCOMP][IFVALUE]album artist,[album artist],Various Artists[]\[album]\[IFMULTI]Disc [disc][]\[track] - [artist] - [title][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[IFMULTI]Disc [disc][]\[track] - [title][]
    But I get the following results using [Multi Encoder]
    %MyMusic%\Mission of Burma\Live from Sound Opinions, Vol.1\01 - 2Wice.flac
    Using the same naming convention, I get the expected results using the "normal" FLAC encoder:
    %MyMusic%\Various Artists\Live from Sound Opinions, Vol.1\01 - Mission of Burma - 2Wice.flac
    I appears that the "Compilation" tag is not getting passed to the Multi Encoder. Is this a known issue with Multi Encoder? an issue with my naming convention? etc.
    Any help would be greatly appreciated,
    Brian
    Configuration details:
    dBpoweramp Music Converter
    Release 13.1
    Registration Status
    Reference: Registered
    Codecs Installed
    Encoders (write)
    [Calculate Audio CRC]
    [ID Tag Update] Release 1
    [Multi Encoder] Release 3
    [ReplayGain] Release 2
    Audio CD (see CD Writer)
    Bwf Mp2 Release 5
    .wav
    FLAC Release 12 (FLAC 1.2.1)
    .flac
    Monkeys Audio Release 8 (Monkeys Audio v3.99)
    .ape
    Mp2 Release 5
    .mp2
    mp3 (Fraunhofer IIS) Release 1 (Fraunhofer IIS v4.0.3)
    .mp3
    mp3 (Lame) Lame 3.98
    .mp3
    ogg vorbis Release 14 (Ogg v1.1.3 Vorbis V1.1.2)
    .ogg
    Test Conversion
    Wave Release 13.1
    .wav
    WavPack Release 5 (using WavPack 4.4)
    .wv
    • 43930
    Re: Compilation tag not being passed using [Multi Encoder]
    Make sure you are using hte latest:
    Updated to latest R13 naming conventions. Also corrections to naming which will now correctly limit the filename length. Bug Fix: Could not type a directory name longer than the visible output to folder. Download: http://www.dbpoweramp.com/codec-central.htm
    And that CD Ripper is set to write the ID Tag Compilation.
    • brianblank
      • Apr 2007
      Sorry for the delay... I didn't have the Compilation tag checked, everything is working great now.
