Do I keep vary drive speed each pass + Do I interpolate unrecovarable frames?
  • poetryrocksalot
    • Jul 2008
    • 12
    What do these function do?
    Also, what has better accuracy, ripping at maximum speed or minimum speed? Apparently I can only set Drive Speed under "Individual Bad Frames" so what do I select for that speed for best quality and accuracy? And what is mark track as error if insecure.
    What happens if I do not interpolate unrecoverable frames? Or Vary drive speed.
    What is the maximum quality and accuracy settings for ripping as .wav format?
  • EliC
    • 1175
    Re: Do I keep vary drive speed each pass + Do I interpolate unrecovarable frames?
    With most drives you can safely rip at max speed. If you are having trouble getting good rips, slow the speed down. If you have a problematic disc you can also try to slow the speed down.
    Instead of finishing the rip with possible pops/clicks/ect the rip will be aborted and the track marked as insecure
    If you want the best quality, do NOT interpolate unrecoverable frames, this is basically a guess as to what should be there when the drive can not read it.
    There are no quality settings when ripping to wav - it is a lossless format and the quality is all 100%. I would suggest ripping to a different codec that offers some compression while also being lossless - FLAC is the most popular and well supported.
      To keep the WAV the same quality level as the original CD, rip to 16-bit, stereo 44.1KHz.
      • Porcus
        • Feb 2007
        • 792
        Actually, .wav is a container format. For ripping to wav, follow LTData's advice -- but as EliC mentions, choose a different format. FLAC also has metadata capabilities.
        • bhoar
          • Sep 2006
          • 1173
          I agree. I suspect this feature interpolates the entire frame when C2 cannot validate parts of the frame. If I rip with secure/ultrasecure and leave this option on when ripping badly damaged discs then:
          1. Without C2, don't notice a problem.
          2. With C2, I get lots of drop outs.
          So, I make sure it is always off. Perhaps the feature might be suited for certain kinds of audio (perhaps with lots of silence/quiet periods in it)?
          -brendan
