Ripping problem with BenQ drive
  • Evil Disco Guy
    • Jun 2007
    I have two optical drives, a BenQ DVD DC DW1670 and a Toshiba DVD-ROM SD-R5112. The BenQ is my primary drive but every now and then I have problems when ripping. It's only happened a few times but it's making me wonder.
    Basically I rip a CD and when it comes to the last track or two the drive slows down, goes through two passes and normally ends up having to re-rip a small amount. Normally the AccurateRip result is good and the CRCs match but it's annoying/worrying. If I then put the disc into my Toshiba drive I have no problems at all (plus same AccurateRip and CRC results).
    Any reason? Is it because the BenQ is ripping at a much faster speed than the Toshiba?
    Re: Ripping problem with BenQ drive
    If your drive is re-ripping some of it and it happens on many discs in a row, your CD drive might be dropping down to PIO mode, see here for an explanation: http://forum.dbpoweramp.com/showthread.php?t=4619
    If that is not the problem, then I believe dMC is set to vary the speed with each pass and, of course, slower reading normally means better results.
      • 43930
      Many drives have problems reading the last section of cds, some drives are worse than others.
