I'm have problums with using the normalize feature.When I set up a group of fies to normalize everthing seems to work fine,but when I listen to the files there are clicks on pops that were not in the original files.They seem to be most noticable at peak notes.Could this be clipping?How can I make this stop?:headbang:
Sound quality issues
Yes, reinstall it - then for volume normalize just select the top default simple normalize option. Then uninstall it.Comment
:happy: Well I had a wild idea that maybe running a full scandisk to check for errors and bad sectors would be a good idea.:happy:It found 3 files in bad clusters,I;m assuming they had something to do with Wave/mp3 playback because all is fine now.
Thanx for your help and time. :supersmilComment
very frustrated
I had fixed all problems thanx to spoons advice and my own ideas,All was fine,but all of a sudden my files still have static and poping noises in them after I use simple or any other normalization options.This time I used a clean install of DMC without the power pack,why wont this program work for me!!!!!!!!!! :headbang: :vmad: :thumbdownLast edited by KliKKlaK; 11-21-2002, 07:43 PM.Comment
I cannot guess what is happenning, it is probabbly best not to use the normalize if it is not working for you.Comment
ok
thats the only reason i got the &%$# thing in the first place,but it works now so yeah and thanx for your help.I used a registry editor to clean up a bunch of crap from old installs from many different audio programs.so far so good,my entire funky breaks collection is now normalized!:happy: :supersmil :D :smile2:in case you havent noticed I'm moody:shocked:Comment
