freedb connection
  • James
    Works Now
    Thanks for the quick reply. No, I didn't try any of the suggestions because I didn't understand them. I restarted the PC then I could connect to freedb. Weird, huh!
    • ralf
      • Jan 2003
      I installed dMC on a winNT4 and a Win98SE2 system and everything seems OK. Now I tried a Win95 system... no freedb-connect.
      All in the same LAN, all the same settings....
      ...help?!
      • MODatic
        • 230
        Have you visited and installed some of the stuff on this page. (esspecially Winsock 2)
        • ralf
          • Jan 2003
          ups, no i didnot. When I doubleclick the winsock exe nothing happens. it's just a selfextracting zip, right? Where should those files be placed? in the System folder c\windows\ ?
            • 43990
            It is a Microsoft install, a program should run, try some of the other updates first.
