I searched and searched for an answer but could not find one... When I reconvert my songs (for lower bit rate) they are shorted to only 10 sec instead of the full length why is this? How do I fix it?
I need help pls!!!!
Re: I need help pls!!!!
What format are you converting to? mp3? Do you have a registered version of dMC or an unxperied trial version? Otherwise you cannot use the mp3 encoding codec. -
Originally posted by ChristinaSWhat format are you converting to? mp3? Do you have a registered version of dMC or an unxperied trial version? Otherwise you cannot use the mp3 encoding codec.
I have the registered version.I'm converting to mp3. Im not having problems converting it's just when it converts my songs get shortened to 10 sec and not the full length.Last edited by dimpelss; 07-24-2006, 02:07 AM.Comment
Originally posted by dimpelssI have the registered version.I'm converting to mp3. Im not having problems converting it's just when it converts my songs get shortened to 10 sec and not the full length.Comment
