upload doesn't work
  • jcondon
    • Mar 2006
    upload doesn't work
    the utility for loading music into my player (Cabo) worked until it expired, so I paid to register, overwrote the old version, and now it says its expired and won't work. HOw do I make it work?
    Re: upload doesn't work
    You paid for Sveta or the PowerPack and MP3 Encoder License or both? If you paid for Sveta and are trying to send mp3 files, you can't do this. If you paid for the PowerPack and MP3 Encoder License only you can no longer use Sveta. If you paid for both, try the total uninstall mentioned here: http://forum.dbpoweramp.com/showthread.php?t=6828. Then reinstall your registered install.
