Ripping Error on Secure, but not on Burst or DBD?
  • KingZorc
    • Jul 2018
    Came across a CD where every tracks rips and verifies perfectly, but the last track throws up ** Drive is unable to read into lead out, uncheck over-read option. [clRipperSecure::Rip]
    This happens even after I uncheck the over-read option. If I rip the track in Burst or Defective By Design it comes out fine with an Accurate next to it. So what's stopping Secure from ripping the last track correctly?
    • 43930
    Re: Ripping Error on Secure, but not on Burst or DBD?
    What drive do you have? and what is the drive offset?
    • KingZorc
      • Jul 2018
      Hl-dt-st - bddvdrw ch08ls10
      667
        • 43930
        It is possible that it is something unique to this drive and disc, a different drive would not have this issue.
        Ripping burst does not use C2 pointers (if they are enabled).
        • KingZorc
          • Jul 2018
          If I keep Secure enabled, but disable C2 Pointers then the last track rips fine as Accurate with a verified CRC. Wonder why C2 Pointers are messing up the ripping only on the last track and only for this specific CD so far.
            • 4015
            Probably just a minor problem with your drive firmware. If all is OK with the C2 Error Pointers for Error Detection option disabled, then I wouldn't be concerned.
