Asset Problems with Windows Home Server V1
  • mahl
    • May 2013
    Hello,
    I have installed Asset on my Acer Easystore H340 with Windows Home Server V1 via Snap In. Everythings seems to work fine, but my Streaming Clients (foobar, Pioneer N-30, Philips N2500) do not see Asset. When I restart the Server, sometimes it works for a while (sometimes Minutes, sometimes 1 Hour). After that, Asset is no more to see. When I restart the Server 3 or 4 times a "new game" starts with the same results.
    On the Server runs also "Windows Media Connect". May be this the Problem?
    Greetings
    Thomas
  • dbfan
    • Jan 2011
    • 937
    Re: Asset Problems with Windows Home Server V1
    Windows media connect is not the problem, if it work for a short while either:
    Something (firewall) is blocking asset, do you have security software on the whs machine?
    It is a network issue, open a Remote Desktop connection to the whs machine, leave it open until asset goes, if you can still do things in Remote Desktop then it should not be a network issue.
    Or it could be asset is crashing, if you open a Remote Desktop connection and wait 2 minutes if asset crashed windows would show an information message about asset stopped working.
    • mahl
      • May 2013
      The MC Afee Internet Security was the Problem. Now Asset runs. Thanks for Support. Great Program.
      greetings
      Thomas
      • yellowspider
        • Oct 2013
        • 26
        With my Linn Majik DS I have dropouts during playback of hires and also dropouts between 16 bit tracks sometimes. I´ve tested some devices as source for the flac files.
        The problem is the Windows Home Server Acer 340 with asset running on it. Mirrors are off, i use the home server only for streaming and some manual backups. Nothing else.
        The problem is posted already in the Linn forum:
        Any ideas to solve the problem?
        • yellowspider
          • Oct 2013
          • 26
          Hello@all,
          I´ve also problems with dropouts on my Linn DS. After trying different sources for my flac files and checking the connections (LAN cable, DLan instead of cable) the problem can be broken down to the Acer H340 with WHS v1 with asset as music server software. See more Details in my thread on the Linn board
          Need your help please.
            • 43930
            See:
            • yellowspider
              • Oct 2013
              • 26
              Hi Spoon,
              thx, but this didn`t solve the problem. Still dropouts.
                • 43930
                The Acer connects to a switch or router and the player connects to the same?
                • yellowspider
                  • Oct 2013
                  • 26
                  The Acer is connected to my fritz.box router. The Majik DS is connected to a switch, which then is connected to the router. I´ve also tried the connection of the DS directly without switch and also connected it via Dlan to the router to make sure, that the cable is ok. Always with dropouts :-(
                    • 43930
                    Have you tried Acer connected to the switch (same as the DS)
                    • yellowspider
                      • Oct 2013
                      • 26
                      Not yet. Will try this later this evening.
                      • yellowspider
                        • Oct 2013
                        • 26
                        Just connected the Acer to the same switch as DS. Dropouts...
                          • 43930
                          Try remote desktop connection to the WHS machine, have a look at task manager to make sure nothing is running and taking up CPU time, install:
                          Monitoring hard disk health and temperature. Test and repair HDD problems, predict disk failure.
                          (the trial)
                          and check the health of your HDD(s)
                          • yellowspider
                            • Oct 2013
                            • 26
                            Health is ok according to hdsentinel. CPU is rising always with asset process when dropouts occur.
                              • 43930
                              Rises to which % ?
                              The files are being served 'as is'?
