Seemingly Simple Question
  • rjcrouch
    • Aug 2020
    OK, It's been a while since I used the batch converter, and I had to reinstall it on a new computer. I'm noticing changes. I simply use the program to make mass filename changes in Windows. For example, if I want to rename every file to start with it's track number. It used to be very simple - I select the folder, hit convert, and it took me to the appropriate menus. Now it takes me to a menu talking about lame MP3's and bit rates and all sort of things I don't want to mess with. How do I go back to simply renaming files?
    Sorry I'm sure this has been covered many times.
    Thanks in advance!
    • 43936
    Re: Seemingly Simple Question
    You need 'Tag from Filename' here:
    • rjcrouch
      • Aug 2020
      https://www.dbpoweramp.com/codec-central-utility.htm
      Thank you!!!!!
      • rjcrouch
        • Aug 2020
        That worked - thanks!
