Unchecked Tracks I Didn't Want but They Have Still Been Ripped, Why FFS?
  • ChisChas
    • Oct 2017
    • 78
    I've now ripped 80 CD's and as I don't like every single track, on every single CD, I uncheck those I don't want and then rip. Why is Ripper ripping the unchecked tracks? Only just noticed so now I have a HUGE admin job to go back over all the CD's where I didn't rip the entire CD.
    • 4015
    Re: Unchecked Tracks I Didn't Want but They Have Still Been Ripped, Why FFS?
    Prior to ripping, try right-clicking on any track and select the Rip Selected option from the context menu.
    • ChisChas
      • Oct 2017
      • 78
      Thanks for the quick response, so unchecking the tracks you don't want, doesn't guarantee the programme won't decide you should have them? What is a 'context menu and where do I find this? It is laborious enough to rip 400 CD's (especially when you ripped all 400 in WMP WAV only last July) but do I have to uncheck & then right click on any track and select the Rip Selected option from the context menu? And will I be warned about this in the notes for CD Ripper?
        • 4015
        Context menu - Wikipedia
        • ChisChas
          • Oct 2017
          • 78
          Very good, M8. So I think you're saying that I have to add another stage to an already laborious process and I have to uncheck AND then select Rip Selected? In the much maligned WMP, if you uncheck a track it's not ripped LOL
          • ChisChas
            • Oct 2017
            • 78
            If you select Rip Selected, it will only rip that one track and none other so that suggestion doesn't help at all.
              • 4015
              I hope you aren't here to defend WMP?
                • 4015
                Then I don't know what to suggest as I always rip the entire CD.
                  • 4015
                  Hmm, using CD Ripper R16.6, Rip to FLAC, I just inserted a 24 track CD, selected tracks 2, 8 and 23 and clicked the Rip button.
                  Result: 3 tracks ripped, tracks 2, 8 and 23.
                  • ChisChas
                    • Oct 2017
                    • 78
                    Out of about 80 CD's ripped so far, 15 fall into the 'not all tracks wanted' category so I've had to go into each dbpoweramp CD folder and more than half of the 15 have ripped unchecked tracks so it has created a lot of clerky work to manually delete those tracks.
                    Is it possible the CD Ripper gets 'confused' if you start to rip before finishing the unchecking of unwanted tracks process? I'm trying to figure out the inconsistency
                    • ChisChas
                      • Oct 2017
                      • 78
                      See my post 'suggesting' that starting the rip process 'might' confuse the CD Ripper. I am now waiting until I've finished unchecking un wanted tracks before starting the rip. This seems to work. I was trying to save time by starting the rip whilst unchecking at the same time (where track 1 was wanted) as you can finish unchecking whilst track is being ripped. Appreciate that dbpoweramp works a bit differently to WMP but you can defo uncheck 'on the hoof' with WMP. As a matter of 'good practice', I am now checking immediately after ripping any CD when some tracks aren't wanted.
                        • 43929
                        You have to uncheck the tracks before clicking Rip.
                        • ChisChas
                          • Oct 2017
                          • 78
                          Yes, I discovered this, luckily I noticed the problem after only 80 CD's had been ripped. Some 15 were on a 'not all tracks' basis & I had to check each one deleting unwanted tracks as I went along. Is this important tip/hint in the rip notes? If not, can you add it please?
