Tracks associated with Wrong CD
  • IanP
    • Feb 2019
    Problems with Assett server viewed with Linn Kazoo on i pad
    Kazoo does not display the art work.
    Perfect Tunes found most of it and seems to have placed a jpeg in a folder on most of the CDs on the Qnap.
    How can I get Kazoo to display it.
    I tried to rescan with Assett for new and changed but it did not find the art work.
    More importantly it kept all the tracks together in order but associated them with the wrong CDs.
    I did a full rescan but the problems persist.
    When viewed in Windows Explorer the tracks are associated with the correct cds and there is relevant art work in each folder.
    I should be grateful for your help.
    • 43990
    Re: Tracks associated with Wrong CD
    You would do a rescan (Refresh all). You would have to also check that the files do not have an embedded album art. Also if folder.jpg is written, you need your albums in separate folders.
    • IanP
      • Feb 2019
      I have tried rescan all but it has not cured the problem.
      • IanP
        • Feb 2019
        On the second rescan Assett sucessfully asociated the correct tracks on each cd.
        The art work is not displayed in Kazoo although it is present in the folder under the cd header.
          Super Moderator
          • 1368
          Thanks for the bug report.
          Please open Asset settings, click Download Configuration Dump: Complete (large file); send the file to peter@dbpoweramp.com for analysis.
          If the file turns out to be too large to transfer (contains whole album art cache), send me an email and we'll figure out an alternate way of sending it.
