Left folder pane - blue music note icon - what does it mean?
  • danclark
    • May 2021
    The picture attached shows folders, drives. The top 5 have the blue music note icon.
    Some are music folders, but others are drives.
    Does PerfectTunes add this icon based on folder settings?
Name:	Screenshot 2022-04-05 170531.jpg
    Version 3.5, Win 10
    • 43936
    Re: Left folder pane - blue music note icon - what does it mean?
    Something looks a little off, I just tried on mine and for drive C it had the same. Will look next time updating PT.
    • danclark
      • May 2021
      I will soon install PerfectTunes ID Tag on a new WIN 10 PC. I want to configure folders correctly so PerfectTunes properly shows the music folders in the left pane.
      Can you recommend the correct folder settings for this?
        • 43936
        The music folders are just collated from Windows Music Libraries:
        Add existing folders of music, pictures, or videos to the corresponding libraries. You can also remove folders from libraries, get the list of folders in a library, and discover stored photos, music, and videos.
        • danclark
          • May 2021
          Is there a layman's guide to configuring Windows music folders that will be recognized by PerfectTunes ID Tag?
          I don't know C*, Visual Basic, C++ or other programming language in that MS link on Libraries.
          Thank you very much for this great service.
            • 43936
            If you have files scattered across different locations, you can use libraries to organize and bring them together in a single view, and in this guide, we show you how on Windows 10.
