Album split in two parts
  • marsu
    • Dec 2015
    I have AssetUPnP running on a Raspi accessing my TrueNAS media folders. Usually all albums there are in one folder. But why does Asset split one album / one folder in two separate albums where one has 6 tracks and the other one has 3? I do not understand any reason on my side for this mistake in indexing. Any ideas?
    BR
    Marsu
    • 43929
    Re: Album split in two parts
    Because often people have albums which have the same name, such as 'Greatest hits' and no indication they are compilation albums. At a guess 99.999% of people have albums always in the same folders, so it is an easy assumption that albums are identified both by album name and location.
    In your case this is not the case, so there is an option on the configuration page 'Album Defined by Folder', uncheck it.
    • marsu
      • Dec 2015
      Sorry I do not get it. It is not a compilation album. Just look at the screenshots.
ID:	294465Click image for larger version
ID:	294466Click image for larger version
        • 43929
        The fix is to correct compilation albums, yours is not, however it is my understanding your album is in different folders, that is why asset is putting as 2 albums. Either bring all the album files to one folder, or un check the option I mentioned.
        • marsu
          • Dec 2015
          It is in one folder:
          marsu@radjah % ls -ln [Dire Straits/Brothers In Arms - 20th Anniversary Edition]
          total 4569036
          -rwxrwxr-x 1 501 1001 221181663 4 Okt 2020 01 - Dire Straits - So Far Away.dsf
          -rwxrwxr-x 1 501 1001 357381861 4 Okt 2020 02 - Dire Straits - Money For Nothing.dsf
          -rwxrwxr-x 1 501 1001 178378441 4 Okt 2020 03 - Dire Straits - Walk Of Life.dsf
          -rwxrwxr-x 1 501 1001 277976805 4 Okt 2020 04 - Dire Straits - Your Latest Trick.dsf
          -rwxrwxr-x 1 501 1001 360863431 4 Okt 2020 05 - Dire Straits - Why Worry.dsf
          -rwxrwxr-x 1 501 1001 294319849 4 Okt 2020 06 - Dire Straits - Ride Across The River.dsf
          -rwxrwxr-x 1 501 1001 198547176 4 Okt 2020 07 - Dire Straits - The Man's Too Strong.dsf
          -rwxrwxr-x 1 501 1001 155449030 4 Okt 2020 08 - Dire Straits - One World.dsf
          -rwxrwxr-x 1 501 1001 294778596 4 Okt 2020 09 - Dire Straits - Brothers In Arms.dsf
            • 43929
            Select all the tracks in windows file explorer >> right click >> edit is tags
            Then post a screenshot please.
            • marsu
              • Dec 2015
              Do you mean this one?
Name:	Screenshot 2021-08-15 153906.png
                • 43929
                No, if you do not have dbpoweramp, install the trial here:
                dBpoweramp Music Converter - mp3 converter, FLAC, WAV, AAC and Apple Losslesss. Free Download (21 day full trial), start converting today
                We need to see the ID Tags inside those files.
                • marsu
                  • Dec 2015
                  Now I see a difference matching to the two different groups: for one the Album Artist entry is missing.
Name:	Bildschirmfoto 2021-09-11 um 16.16.53.jpg
