Initial Caps on file names after ripping
  • snowdog
    • Jul 2019
    • 123
    Hi all.
    I keep forgetting to go into the album details before I rip it & select "capitalise tags".
    Is there an automated way to do this after the album is ripped?
    • 43928
    Re: Initial Caps on file names after ripping
    Install the ID Tag update utility codec (from codec central), the convert the files to this codec and choose the option 'Capitalize'
      • 5744
      I believe you can add this DSP (or a similar ID tag DSP) to the DSP section in the ripper program, so this is automatically done after ripping.
      • Oggy
        • 697
        Yes you can set it up to work when you rip (encode) your CDs.
        Add ID Tag Processing - Manipulation - Capitalization. Then you have a choice of:
        All Lowercase
        All Uppercase
        Capitalize First Letters
        Smart Capitalize First Letters
        I have tried it and it works as expected. You obviously lose the WYSIWYG on the CD Ripper and Manual Meta Review page.
        • snowdog
          • Jul 2019
          • 123
          Thanks for the replies, everyone Supremely helpful, as ever.
