Problems configuring
  • zzdpmjpr
    • Aug 2012
    • 9
    I have been happily using 14 for about 10 years with few if any problems.
    I have just changed a pc and Accuraterip doesn't recognise the drive. I have tried about 20 cds all of which have been rejected with the message below.
    AccurateRip
    This Key Disc cannot be used for offset detection it does not
    match the AccurateRip stored disc, or your drive does not
    exist in AccurateRip and this disc has multiple pressings
    stored. Please try a different Key Disc.
    Some of the disks I tried were definitely on the a key disks list on the Accuraterip website. Having spent/wasted a couple of hours on this can anybody help me find a way out. Being old and non technical I am not sure I even understand the message
    Thanks in advance
    • 43928
    Re: Problems configuring
    Your new drive must not be in the database otherwise it would configure on 1 known disc.
    Your keydiscs can only be used if they do not have other pressings in the database, keep trying discs.
    • zzdpmjpr
      • Aug 2012
      • 9
      Thanks for your response.
      I tried 20 yesterday - all failed. I tried 2 just now - both worked!! The wind must have changed direction.
      Am back to normal now..............well almost.
      Kind regards
      • hvidt
        • Feb 2024
        I have the same problem as the one described in the original mail. Is is only a question of trying a lot of CD's or could it also be that my new CD rom drive is not on the list at www.accuraterip.com? My new drive is an ASUS BW-16D1X-U
        Not having the Accuraterip, forces my drive to make two passes for every track ripped.
          • 43928
          You can keep trying new discs.
