having rebooted my comp my POWER PACK now shows a 30 day trial it was previously regestered can this be righted
power pack
Do you have access to the registered Power Pack? If you do, reinstall that over the top and if that doesn't work, fully uninstall dBpowerAMP as well as the power pack then reinstall everything, including the power pack.
If you don't have access to the registered Power Pack, then:
Pop an email to dbpoweramp@dbpoweramp.com with the name you registered it under as well as your ref number and Spoon will sort you out.Last edited by MODatic; May 02, 2002, 06:53 AM.
