Conversion Speed
    Conversion Speed
    Why does it take 28 minutes to convert a 4 minute wmv file to mp3? I checked the Task Manager and DBconvert.exe was only using 6-10% of the CPU. I am running XP Pro with a 2ghz clock and 256mb ram also a 1.6gb swap file. WHat am I not doing correctly. I can open Windows Move Maker and Windows Media Player. Play the wmv with media player and record a wma with movie maker in 4 minutes.
    • 46229
    Do you have the WMA v9 decoder?
    • BobLfoot
      • Oct 2002
      Conversion Results
      I am registered now and performed a test and here are my results. I used a Toshiba Satellite 1905-S301 with 256M ram and a 2.0 ghz P4 Processor. My Operating System is Windows XP Pro with IE6 SP1. I downloaded the most recent DBPowerAmpConvertor, the Windows Media V9 Codec both parts and The Power Pack. After all where installed I rebooted and proceeded to convert files.
      Source File Statistics
      Windows Movie {*.wmv} for Media8
      320 x 240 at 768kbps
      Length 3m 54s
      File Size - 20,172Kb
      WMA 9 Conversion Results
      192 Kbps with stero 44k Continuous Bit Rate
      Conversion Priority High
      Conversion Time 11m 48s
      Sound Quality - Nothing but buzzing bees upon playback
      Reported Clip Length 2h 36m 41s
      File Size - 221,160Kb
      MP3(Lame) Conversion Results
      CBR - Stereo - 44,100hz
      Conversion Time 14m 47s
      File Size - 220,344Kb
      Wav Conversion Results
      44,100hz CD Quality 16 bit Stereo
      Conversion Time 2m 09s
      File Size - 1,619,515kb
      Needless to say so far DBPowerAmp performs like a piece of junk.
      BobLfoot
        • 46229
        Looks like a problem with Video files, it seems to be converting the video stream into sound...no good. I will look into it, hoepfully sometime this weekend. Drop me an email to dbpoweramp@dbpoweramp.com so I can keep you informed.
          • 46229
          See here:
          http://forum.dbpoweramp.com/showthre...?threadid=1206
          • BobLfoot
            • Oct 2002
            New Beta Codec works much better
            The new Codec you linked to in your post worked much better in terms of time and performance. Is there a reference anywhere which explains the DSP's and their uses that come with Power Pack.
            Volume Normalize and DC Offset are my first questions.
              • 46229
              Have a look in 'dBpowerAMP Music Converter Help' first page index has a link to the DSP effects.
