CODEC required could not be opened
  • Frank Lekens
    I've seen a few references to this problem on Usenet, but so far no
    solutions.
    I have Dbpoweramp installed (no PowerPack) with a number of codecs. So far, it has always worked fine for me. But now when I try to convert a file, the programme suddenly says 'The CODEC required to convert xxx could not be opened'. I first noticed it when I tried to convert an mp3 to a WAV. I haven't checked all the other formats, but trying out one or two seemed to suggest that the problem is programme wide, i.e. it's not restricted to the wav-writer codec.
    The required codecs are certainly available, and I've already tried
    uninstalling and reinstalling the programme, but that doesn't help.
    Does anybody have an idea what the problem might be?
    • 45880
    Re: CODEC required could not be opened
    It should be either:
    'The CODEC required to compress
    or
    'The CODEC required to decompress
    • Frank Lekens
      Sorry. It's 'the codec to decompress' that can't be opened.
      Compressing from wav to, for instance, mp3, does seem to work.
      (And maybe I should say that this is on a WinXP system.)
        • 45880
        Convert any wave file to mp3 using dMC, then try to convert that mp3 to wave, still get the error?
        • Frank Lekens
          Yes.
            • 45880
            Try uninstalling dMC, then install the latest version.
              I get a simmilar problem trying to convert to WMA professional.
              'the codec required to compress ______ could not be opened'
              im trying to rip from a cd to 'VBR Quality 98, 44 kHz 5.1 channel 16 bit VBR'
              Ive already tried reinstalling the program, and windows media 9, but no luck.
              If you could also help me that would be great.
              -Snailman
                • 45880
                For any WMA Pro, with the 5.1 channels - it will only compress if the source is 6 channels, a CD is only 2.
                • Frank Lekens
                  I already tried that, and it didn't work. I can try again, and also un-install all the plugins first, and then re-install those, but I doubt that this will have any effect. E.g., I wouldn't install it to a different directory.
                    • 45880
                    You can perhaps install the Lame CLI encoder from Codec central.
                    • Frank Lekens
                      There seems to be no need to, after all.
                      I did as I said: uninstall not only the programme, but also all the codecs I had installed. I rebooted and then reinstalled the programme and some of the codecs, and at first sight things seem back to normal (at least I could create a wav-file from an mp3). Thanks for the patience.
                        I have had a similar problem converting FLAC to MP3. It worked the first time, now when I try on other files I get the same error "The codec required to decompress could not be opened". I have re-installed the FLAC codec but have not re-installed the software. I also rebooted thinking the software had not "let go" of the FLAC codec. I have tried at various quality settings as well, in addition to attempting to convert using the right click menu and the program icon.
                          • 45880
                          1 or more bad FLAC files?
                            I'm have the exact same problem converting FLAC files (codec could not be opened). I've now tried:
                            -uninstalling and reinstalling dbAmp and codecs (on both PCs)
                            -using multiple FLAC files from different sources (on both PCs)
                            No luck. I know the FLACs are good because I ended up converting them with with the WinAmp/ Nero plugin. I'd rather use the dbAmp.
                            Any ideas? Thanks.
                              I'm having the same problem with FLAC. All the other file types work fine.
