Problem with some low resolution art
  • JohnJScott
    • Sep 2023
    Some files (wma) show it is missing art - but when I click fix, there is existing art (admittedly typically at low resolution) This art cannot be exported to Folder.jpg either.
    What is the issue here?
    Cheers
    John
    • 43936
    Re: Problem with some low resolution art
    It is possibly in a hidden folder.jpg file already
    • JohnJScott
      • Sep 2023
      Being a dev myself, I always have show hidden files on, and I just double checked - there is no folder.jpg file hidden or otherwise.
      I could send you an offending file?
      I'll have a go at debugging myself (MediaInfo.dll ftw) - my first guess would be an unsupported PerfectTUNES image format, but supported by explorer. (gif? bmp?)
      Cheers
      John
      • JohnJScott
        • Sep 2023
        My bad, there was a hidden system folder.jpg. It didn't show up with show hidden files until I went to the folder options and unchecked 'Hide protected operating system files'
        Thanks for the tip!
        Cheers
        John
