Help converting .mka files
  • TeuchterLoon
    • Nov 2014
    Hi, I hope this is in the correct forum.
    I have an album ripped in 24/96 5.1 DTS Master Audio which is in .mka format. Unfortunately, nothing seems to support tags with .mka files, so I am looking to convert it to .Flac (or another format you guys might recommend?) - retaining the 24/96 5.1 Lossless audio. Is this possible with dbPowerAmp?
    Thanks in advance for any help :-)
    TL
    • 43985
    Re: Help converting .mka files
    Sorry it is not.
    • Overlord_Laharl
      • Aug 2015
      sorry for necro posting, and if this doesn't help you it may help someone else
      mka is matroska container format meant for audio only
      you can use a few different the matroka tools to "demux" it (think of demux like extracting a zip))
      the official tool is called mkvtoolnix however mkvtoolnix does not include a demux gui
      for both of the following tools ytou will need also mkvtoolnix https://mkvtoolnix.download/ in addition to the tool
      if its just one file i recommend mkvextract 2 https://sourceforge.net/projects/mkvextractgui-2/
      if its multiple files i recommend mkvcleaver http://blogs.sapib.ca/apps/
      i use mkvcleaver to batch demux flac audio files, then i use dbpoweramp to convert those to aac. followed by a script to remux them (remux is like making adding files to a zip)
      of course there is no guarantee the demuxed audio will be compatible with dbpoweramp.
