Delete audio up to a named cue point?
  • chrisjj
    • Nov 2008
    • 299
    Can I set an Effect to delete the audio up to a named cue point?
    • 43927
    Re: Delete audio up to a named cue point?
    There is a DSP 'Trim' which trims a certain amount from begin or end.
    • chrisjj
      • Nov 2008
      • 299
      Thanks but AFAICT Trim does no more than http://www.dbpoweramp.com/dbpoweramp-dsp.htm says: " Trim remove fixed length from beginning or end".
        • 43927
        Yes and you asked "Effect to delete the audio up to a named cue point?", so if your named cue point is 60 seconds in, you can set trim to remove the first 60 seconds always. Perhaps I miss understand you?
        • chrisjj
          • Nov 2008
          • 299
          Sure, but the named cue point is not be at '60 seconds always'.
          I have hundreds of tracks with cue points named "*1" at different positions. I apply one automatic operation in GoldWave using this. I'd like to do the same in dbPa.
            • 43927
            Ah a cue point as indicated by the file. dBpoweramp cannot use this.
            • chrisjj
              • Nov 2008
              • 299
              Ah, sorry. I took that as given.
              OK, thanks.
