Problems: Caused by BubbleUpnp, Asset or what?
  • Balderick
    • Dec 2013
    • 55
    I have only limited overall success with my method of playing my digital collection. But have a problem and it's difficult, if not impossible to tell where the issues lie as there are so many components and factors. How does one find and fix the unending issues?
    While there are many small issues, the one that I find most irritating are the missing files and songs etc, of course only when I want them.
    Here is one that I see somewhat frequently. Windows Explorer will see all the files I expect in a folder on the Synology. Asset has been regularly Detecting Changes and sometimes refreshed completely. Yet Bubble UPnP will either see none, or only some of the files that are supposed to exist. Photos and Screenshots to help. My system info is below.
    Any ideas what is the problem? or where I need to start looking closer? Asset? BubbleUpnP? the DS 213? the Files themselves? AAAARGH!!!
    My setup
    COMPUTER:
    Asset 4.1 (Registered) always running on my PC
    My PC: Intel i5-2500 @3.3 GHz, 8 Gb RAM, Win 7 Home Premium SP1, 64 bit
    HOME NETWORK:
    ASUS RT-N56U
    ASUS GX-D1081 Switch
    Plus a few Trendnet Powerline adapters
    STORAGE:
    Synology DS312 DSM 5.0-4458 Update 2 (2x WD Red 3TB drives, RAID 0)
    CONTROL POINT:
    Samsung Tab 3 8"
    Bubble UPnP 1.8.6
    STEREO:
    Anthem MRX-710 AVR
    Moon MiND
    Moon DAC 180
    • 43928
    Re: Problems: Caused by BubbleUpnp, Asset or what?
    Try bringing a selection of problem albums to your local computer hdd, then have asset just scan that folder, does asset have the details then?
    • Balderick
      • Dec 2013
      • 55
      Okay. I copied t albums that could recall having issues with quantities over to my local PC Music folder and added them to the Asset directories to watch.
      The only changes were Coldplay - Parachutes with 10 songs, and ELO - Eldorado with 12 songs and a graphics folder.
      It took Asset 2 detecting changes, a restart and a Refresh all (90 minutes) to find the folder addition.
      Here are the screenshots of Asset before and after. Note that there should be a difference of 2 albums and 22 songs but it shows weird album differences and only 4 songs. The Coldplay album shows Empty/nothing in my Control Point and the ELO album shows the same 4 songs as image in my previous post.
      My Synology Server shows all the songs in both albums when I view it in the same control point. But will not play them.. except the 4 songs that do show in the Asset server. I'm thinking these missing songs are the culprits, but do not understand why.
      BEFORE
      AFTER
        • 43928
        Exclude the main folder from the scanning, so only these albums are scanned, it will make browsing and finding what is going on easier.
        • Balderick
          • Dec 2013
          • 55
          I was going to do that next. I just wanted you to see the wacky numbers I keep getting with Asset. I've pointed this out in posts prior to this thread.
          Here is only that one test folder.
          I've DETECTED CHANGES, REFRESHED ALL and RESTARTED ASSET. With no change to the numbers.
Name:	Asset One Folder 2014-04-20_104525.jpg
Name:	Asset ANYWAY 2014-04-20_104647.jpg
          • Balderick
            • Dec 2013
            • 55
            LOL. Asset never ceases to amaze me with it's counting prowess!! After Refreshing all, Detecting changes, restarting Asset AND restarting the local Computer I now have 4 tracks in 4891 albums!!
              • 43928
              This is to be expected based on the design, you would not see these albums however when browsing.
              • Balderick
                • Dec 2013
                • 55
                But why does it add a remove folders so drastically? I just looked today and even though I removed the 2 Christmas folders (which contain hundreds of folders) from the watchlist I now have another 500 folders?
                  • 43928
                  The album count is just an estimation, it is not exact. However the track count is exact.
