Highest Quality LAME Mp3 Settings
  • Magic08
    • Mar 2009
    Hey there. Sorry if this has been asked before. I searched as best I could, but could not find a complete answer to my question.
    I have some .flac files that I am trying to convert into mp3's. Using dbpoweramp, what are the best options to maintain the highest possible quality in lame format?
    Specifically:
    1. Is Target: Quality (VBR), Bit Rate (ABR), Bit Rate (CBR), or Free Format?
    2. I assume "Slow" for encoding.
    3. Should I keep the frequency as "as source?"
    4. Should the channels be set to: auto, stereo, joint stereo, forced joint stereo, dual channels?
    Again, I'm trying to keep as much quality as possible. Thanks!
    • 43928
    Re: Highest Quality LAME Mp3 Settings
    CBR 320 kbps is the best you can get out of lame. Frequency as source, Channels as auto.
    • Nonreality
      • Feb 2008
      • 29
      240 VBR is nothing to shake a stick at either. Very few can tell any difference between it and 320 cbr. If you can you probably should stick with flac. Saves space too.
