Page 3 of 35 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 512
Thread: Discussion of dMC R12 Alpha
  1. #31
    Join Date
    Apr 2002
    Re: Discussion of dMC R12 Alpha
    or you can switch off wave tagging in R12.
  2. #32
    Join Date
    May 2004
    Any updates? Based on the post on HA I was hoping to see an alpha of the CD ripper soon.
  3. #33
    dBpoweramp Guru LtData's Avatar
    Join Date
    May 2004
    Location
    USA
    See here for Spoon's Development diary, including what he is currently working on: http://forum.dbpoweramp.com/showthread.php?t=9480
    From the post, Spoon is hard at work on the CD ripper. It is taking longer than normal due to him revamping the ripping and making it Secure or, in his words, better than EAC at getting the audio off if it is possible.
  4. #34
    Join Date
    Apr 2002
    Perhaps this week...
  5. #35
    Join Date
    Aug 2006
    Quote Originally Posted by Spoon
    I saw on HA that you were shooting for early this week, is this still the case?
  6. #36
    Join Date
    May 2004
    Location
    USA
    The CD ripper is released. Get it at the link in my signature.
    Also, I'm so close to using this, all I need is a Ogg Vorbis encoder and I am so there.
  7. #37
    kwanbis's Avatar
    Join Date
    Mar 2006
    Hi Spoon, first of all, let me tell you that dbpoweramp is my favorite cd ripper. Al i can say, is only with the intention of improving it.
    In general, i feel like the dbpoweramp interface is non standard. In particular the options dialog box. Is weird, i have to "think it" before using it. I would try to expand latter on the problems. (Shouldn't it be some begginer an advanced options?)
    Regarding the MP3/LAME config, i don't get the drop box with the encoding: fast, normal, low settings. How do they relate to -vbr and -vbr-new? That is the only part i don't get, or that i think is difficult to understand. I would also remove, or put in advanced, the "free format" option.
    But R12 looks really nice ...
    You just need to add support for MAREO
  8. #38
    Join Date
    Apr 2002
    Yes eventually, for the moment all options are thrown in together.
    -vbr-new is used for all conversions, the fast / normal are other older lame options.
  9. #39
    Join Date
    Apr 2002
    > support for MAREO
    See the CLI Encoder link above, it will work with anything...
  10. #40
    Join Date
    Jul 2006
    Location
    Eastbourne, UK
    The R12 Beta is looking good. Do you have an ETA for a FLAC Codec?
  11. #41
    kwanbis's Avatar
    Join Date
    Mar 2006
    so, what would the equivalent of
    -v 5 -vbr-new would be then?
  12. #42
    Join Date
    Jul 2003
    Location
    Las Vegas
    I see that DSP effects have not been implemented as of yet. The two functions I do use quite often are Volume Normalize and Quieten. If I install the latest alpha, will I lose these?
  13. #43
    Join Date
    Apr 2002
    -v 5 will be the same as your line.
    DSP effects would be lost with this alpha, they are not implemented in the slightest yet.
  14. #44
    Join Date
    May 2004
    Location
    USA
    Yes.
  15. #45
    kwanbis's Avatar
    Join Date
    Mar 2006
    but should i also select:
    Slow (High Quality)
    Normal
    Fast (Low Quality)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
