I know this error has popped up more than a few times on the forums -- I promise I went through it all.
I am running XP SP2. I'm rebuilding after a harddrive crash (although I have not used poweramp's real converter before) so this system has not had anything else installed on it that might interfere -- not real player, not the old poweramp codec.
I installed poweramp
I installed directx 9 (redundantly)
I installed real alternative (1.45)
I installed the direct show codec
I configured the direct show codec
I ran poweramp's configuration tool and verified that the extensions show up as being installed
I have repeated the above several times and rebooted many times.
I verified using DirectShow Filter Manager that RealMediaSplitter.ax is loaded (4 filters including "Real Audio Decoder"). I unregistered and reregistered it.
I am trying to convert actual .rm's not metafiles.
Real Alternative works fine, and the .rm's play, so they are not corrupt
I also have the audible directshow filter installed with poweramp, and it works fine.
"Convert to" is presented as a right-click option for .rm so poweramp is recognizing it...
I'm at a loss... any thoughts?
Shaav.
Shaav.
