Installation problem flac converter
  • buffyhair
    • Jun 2005
    I am unable to intall the flac converter. The installation gives the
    error message: "Error whilst running <PATH>\MusicConverter.exe".
    This happens during the installation itself, so I never get to the point
    of actually trying to run the program.
    I know this has been addressed before, but they seemed to be trying
    to install multiple products, and I am just trying to install the converter.
    Any help on this?
    Re: Installation problem flac converter
    Have you already installed dBpowerAmp Music Converter itself? Did you install this codec to the same directory?
    • buffyhair
      • Jun 2005
      Thank you for the reply. I didn't realize this at first, but then
      found some other posts that stated this requirement. However,
      when I go to downloads.com and try to get the recorder, nothing
      happens and the page it comes from is unavailable. Will try again
      tomorrow.
        There is a direct download link on the dMC download page. It is a local link to use only if the download.com link doesn't work. But its recommended to download the latest dMC beta linked to just below in my signature.
        • buffyhair
          • Jun 2005
          First, thank you so much, LtData, for your responses. I was
          able to successfully download the music converter from download.com
          today, and after that the flac codec. So I have made progress.
          Then I installed the player and I found that the "convert to" option
          when I right-click the flac file went away and was replaced by several
          player options. I wound up uninstalling all 3, then re-installed just the
          converter and codec, and "convert to" came back. Any idea why?
          My second issue, and I realize this has nothing to do with your product,
          is that the flac files I downloaded with bit torrent converted to truncated
          wav files. I assume the problem is with bit torrent or the source files,
          and will seek answers there, but if you have any advice I will gladly listen.
          Once again, thank you and have a good day!
            Regarding the "convert to" issue, it can easily come and go due to conflicts with other programs, but most times you just need a reboot.
