Enhanced AACPlus (AACPlus v2) Codec
  • sti3
    • Jan 2006
    Re: Enhanced AACPlus (AACPlus v2) Codec
    32kbps mono doesn't work for me. I get a Codec Error "
    Also the resulting file sounds awful in winamp. I stream to myself in 32kbps aacplus using oddcast/icecast and everything sounds quite a bit better. Am I doing something wrong?
    • drsox
      • Jan 2006
      I have created a GUI for the command line encoder...
      Grab if you fancy!
      fruk.net
      You need the Microsoft .net Framework to run the gui.
      Enjoy.
      Tom - www.mouselike.org
      • bsiegel
        • Feb 2005
        • 17
        #48
        I haven't really been staying on top of this thread - sorry. Anyhow, there's a new reference encoder (26.410 rev 6.50) that I will be modifying once I get back from my classes today.
        The reason encoding is capped at 64kbps is that the tuning tables (devised by the 3gpp consortium) only have tuning entries up to 64kbps. Tiny little changes to this table can alter the sound quality of the outputted file in various ways, and I am far from qualified to be meddling with the tuning tables in this way. However, I can play with the tables a bit to see if I can make good-sounding output at higher bitrates.
        Any other questions you may have, please let me know as I will be periodically checking this thread for the near future.
        EDIT: Update posted in the first thread.
        --Brandon Siegel
        • Phantazm
          • Dec 2005
          Cool!
          • sean_malice
            • Jun 2005
            Thank you for this very fine piece of software.
            Is the source code freely useable ? Is there any licencing scheme ?
            I'm asking this because i was wondering if such AAC+ functionality could be included into Videolan to stream live along with their h.264 codec.
            Thank you.
            • dimzon
              • Sep 2005
              • 14
              #51
              @bsiegel
              please, provide fresh patch (higher bitrate support) too
              • mo5iac
                • Mar 2006
                hi, thanks for this great encoder, I've been using the version 630 with no problems. With the version 650 encoded files I get an error winamp, tcpmp, and vlc. The error in winamp is "Unexpected channel configuration change", and in tcpmp and vlc they play as blank songs.
                Any ideas of what I'm doing wrong?
                • lucky
                  Banned
                  • Nov 2004
                  • 80
                  #53
                  Hi, Why when encoding with dbpoweramp we don't have to encode from a wav and when encoding using the console yes?
                  What i do after encoding is to remove the container using the MP4-AAC-MP4 codec, this names the file .aac. Some players which thinks they can't play aac, they plays it when using a mp4 container, but i think using only aac is the correct way (the only one which i realised that have problems is wmplayer, but using a mp4 container it doesn't recognise the plus of the encoded audio and the sound isn't good anyway).
                  here's the codec
                  • lucky
                    Banned
                    • Nov 2004
                    • 80
                    #54
                    the only problem i have is that the id tags doesn't preserv on the new file
                    when using mp4 winamp doesn't recognize the sbr, but using aac it's 100% perfect
                    • vod
                      • May 2006
                      whats the difference between this encoder and the nero mp4 version2 encoder that we have at codec central (http://www.dbpoweramp.com/codec-central-mp4.htm) ?
                      is this one better than what we have at the codec central?
                      thanks
                        • 43898
                        #56
                        Winamp uses FhG if I remember correctly, the codec central Nero codec only works with Nero v6 or v5. Nero have a new free command line codec, we will be beta testing a front end in the next few days.
                        • Robbienery
                          • Jul 2006
                          Hi! There :smile2:
                          Nice being here with you guys, I've got a question though.
                          I've downloaded the Enhanced AACPlus (AACPlus v2) Codec but I don't know how to install it. :cry: I know this sounds a little silly but I'm new to these things. The program I want to use the codec in is SAM 4 Broadcaster.
                          Can anybody help this newbbie.
                          I'll apreciate any help in advance. :komisch9:
                          Robbienery
                          • ykchoi
                            • Aug 2006
                            According to the 3GPP TS 26.401, their codec implements the HE AAC Profile at Level 2.
                            Unfortunately, I need the level-3 code now.
                            And I'm trying to extend the code to Level-3, but it seems to be not easy.
                            (Level-2: Max AAC sampling rate (SBR present) = 24)
                            (Level-3: Max AAC sampling rate (SBR present) = 24/48)
                            (Level-2: Max SBR sampling rate (in/out) = 24/48)
                            (Level-3: Max SBR sampling rate (in/out) = 48/48)
                            Could you provide any comments to the Layer-3 extension task ?
                            Thanks in advance.
                            • sdeita
                              • Nov 2006
                              I don't know if some one can tell me why I get the following Error Message when I try to generate one .AAC file through the AAC Plus Encoder
                              C:\Norma_Angelica\SYMBIAN_PROJECT\TOOLS\26410-630\26410-630_ANSI-C_source_code\3GPP_enhanced_aacPlus_src_240505Floa tFR_aacPlusenc\Win32_D\CT>enhAacPlusEnc.exe PCM_24_S.wav C:\Norma_Angelica\SYMBIAN_PROJECT\TEST_FILES\ACC_T EST_FILES\AAC_24_S.aac 24000 s
                              * Enhanced aacPlus 3GPP Floating Point Reference Encoder
                              * Build Nov 8 2006, 11:03:55
                              could not open PCM_24_S.wav
                              • mnbruin
                                • Jan 2007
                                Is there any way to make the 3gp output file hinted for streaming servers? Thanks in advance?
