Help with ASPI
  • micaela
    • Jan 2005
    • 9
    Help with ASPI
    Cd writer does not recognize my drive. I ran the aspi check & found that nothing was installed. I ran the installation & now 2 files are not installed - the wowpost.exe & winaspi.dll are not installed. I have the files in the download but don't know where to put them. Can anyone help???
    Micaela
    • 43901
    Re: Help with ASPI
    There are various ASPI installers out there, try a few before getting technical.
    For XP you shouldn't need ASPI.
    • micaela
      • Jan 2005
      • 9
      Re: Help with ASPI
      Thanks for the help Spoon. I am running xp - but have tried 3 different 3rd party burning programs & none of them will work. The Sony product that came w/the computer works fine but I have a lot of ogg files that I'd like to burn cd's from & the bundled software does not support ogg. The ASPI layer was the only thing I found in the help files that seemed probable. Any other suggestions would be greatly appreciated.
        Re: Help with ASPI
        When you hit the Burn button in dCW, do you not get a window where you can select your burner drive?
        Otherwise you can convert your .ogg files to .wav and then use your other buring program to burn yorur audio cd's.
        I am wondering though if your burner has been properly installed.
        Click on My Computer > right click the cd burner drive giving trouble > Properties> Hardware > find your drive again there > properites > properties and explore all about the drive. You can try Trobleshoot, but it may not lead anywhere conclusive. Perhaps you need a driver update too.
        • micaela
          • Jan 2005
          • 9
          Re: Help with ASPI
          Thanks Christina -- yeah, i get the window to choose the drive & then I start the burn & in a few seconds a window comes up that says the drive is not ready & the files have not been written. However after that I am not able to reuse the disks - so something has been written on them. I checked out the drive in windows & all seems to be ok - i didn't find anything unusual or drivers needing updated. I'm stumped.........any other ideas??
          thanks.....
            Re: Help with ASPI
            OK, I had this before, but not necessarily from dCW, rather from any other cd burning program I was using (e.g. Nero)! I think it was related to my defining a drive image thing - so I got rid of it. I can't remember all that well, it was some time ago, after I'd installed my DVD burner in place of the regular cd-rom. I was then left with a cd burner and a dvd burner. It took a while to get them sorted.
            This was a time where I was installing and uninstalling all sorts of stuff.
            I can't even remember how and where I defined the drive image - I guess I'm aging faster than my pc! :p
              • 43901
              Re: Help with ASPI
              Also try selecting a slower burn speed.
              • micaela
                • Jan 2005
                • 9
                Re: Help with ASPI
                thanks spoon & christina -- i did try slowing down the burn time to 12x from 24x -- this is a brand new computer -- grrrrr --and i'm always older than my computers!!!!!! any other ideas?? i haven't tried any other ASPI downloads -but you are saying that shouldn't be a problem w/xp - right spoon? is it worth spending time even looking at that as a solution??
                  • 43901
                  Re: Help with ASPI
                  You could try and verify ASPI is working by using 'dMC CD Input' >> options >> advanced
                  • micaela
                    • Jan 2005
                    • 9
                    Re: Help with ASPI
                    ok spoon i check in the options - advanced section & it lists ASPI under cd communication. does this mean then that it is working fine?
                      Re: Help with ASPI
                      If you can rip cd's that way, then it works. Otherwise you have to change it to another option.
                      • micaela
                        • Jan 2005
                        • 9
                        Re: Help with ASPI
                        ok - i could not rip w/the ASPI setting. I can rip w/the nt2000 i/o setting. now - does this setting help w/the writer also? because after I changed it and found it able to rip - i went back to the writer & it still did the same thing & did not write. If not - how do get that setting to be the default - or is that what I want to do??? where do i go from here???
                        thanks for all the patience & help.
                        • micaela
                          • Jan 2005
                          • 9
                          Re: Help with ASPI
                          also - would changing the command set help the writer any???? i tried a couple different ones & it didn't help - should I keep trying that?
                            • 43901
                            Re: Help with ASPI
                            Command set will not help, if CD Input cannot rip with ASPI then ASPI is not working (you can run the checking programs on the support pages).
                            Also make sure you are logged on as Administrator.
                            • Larry!
                              • May 2002
                              • 46
                              Re: Help with ASPI
                              HERE is a kinda detailed explanation on aspi. Perhaps som burning proggie messed up aspi in your system? Then reinstalling it may help.
