Results 1 to 4 of 4
Thread: Upsampling causes nasty audio effects
  1. #1
    Join Date
    Jun 2002
    I have a bunch of lectures recorded as .wav PCM 8Khz, 16 bit, mono files. When I try to use dBpowerAMP to upsample them (for example, to 11025Hz, 16 bit, mono), the resulting file has a nasty "tinny" (not to be confused with tiny ) quality to it. I can understand losing quality with downsampling, but I would think I could upsample without reducing sound quality. How can I safely upsample?
  2. #2
    Join Date
    Apr 2002
    Download Release 9 - and on the Configuration page enable 'Professional Frequency Conversion'
  3. #3
    Unregistered
    what goes on in Professional Frequency Conversion?
    Out of interest - I am converting a number of stereo wav files from 32000 to 44100 (to be burned to cd) - what goes on when Professional Frequency Conversion is selected converting wav to wav? Is there some algorithmn that calculates the missing samples - some kind of interpolation?
  4. #4
    Join Date
    Apr 2002
    Yes that sort of thing, but it does it much better than the standard windows one.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
