Delphi help
  • jbjorgen
    • Jun 2004
    Delphi help
    When I try to run this code in delphi, I get an eAccessViolation error on the AddFromFile line. Any hints as to what I'm leaving out or doing wrong?
    Code:
    uses
       ..., DMCSCRIPTINGLib_TLB;
    procedure TForm1.Button1Click(Sender: TObject);
    var
        Converter: IConverterDisp;
    begin
        Converter.AddFromFile(WideString('d:\\music\\file.m4a'));        // Add a File
        Converter.GoConversion(WideString('Mp3 (Lame)'),0,0,0,0);     // Convert
    end;
    • 43917
    Re: Delphi help
    I am guessing (as don't use Delphi), that the Widestring is not correct, a BStr is needed (which is slightly different to a normal unicode string).
    • jbjorgen
      • Jun 2004
      Re: Delphi help
      It specifically says in the help that WideString is compatible with the COM BSTR type. There is no BStr function. I think the problem is that the Converter is not initialized properly...
      some kind of Converter.create() or something?
      • jbjorgen
        • Jun 2004
        Re: Delphi help
        all I'm looking for is a quick executable that will take a command line argument and convert it to MP3 lame. It's basically three or four lines of code. If someone could compile it for me, that'd be great.
        • donny
          • Oct 2002
          • 761
          Re: Delphi help
          you are probably right about that converter.create....
          try like this (looselly):
          converter := IConverterDisp.create();
          or something like that any way...
          in my case (for the player) I had :
          amp:= tamp.create(form1);
          then I was able to access amp.volume (for instance)
