Results 1 to 6 of 6
Thread: a log like exact audio copylog at least similar, and in burst mode too
  1. #1
    Join Date
    Mar 2022
    hi
    dbpoweramp cd ripper is an amazing ripper
    1)
    what i do miss (and many others) is a log similar an exact audio copy log
    would love it
    I know in the secure mode , it can create a log , better than nothing but with more info would be great
    2)
    could be enabled and added a feature to create a log (like secure more) even in burst mode ,if cd to rip is present accuraterips database
    thanks
  2. #2
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: a log like exact audio copylog at least similar, and in burst mode too
    Secure ripping mode does a simple burst mode first and if this matches the AccurateRip database, the ripping is done. That is, all the other secure passes are skipped. Given this, I am not sure why anyone would NOT use secure mode. For log make sure you set option to get the most verbose log.
  3. #3
    Join Date
    Mar 2022
    Quote Originally Posted by garym View Post
    Hi Garym
    well , i got a warning about secure mode ,that it does stress the unit and to use the burst mode , recently installed under mac
    should I use secure and leave all the other settings as default?
    thanks ,appreciate your help
  4. #4
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by Drugo View Post
    Hi Garym
    I have ripped many 1000s of CDs all using secure mode and the drives I used are still working fine. Of course 90 percent of those disks matched AR so secure ripping only used the initial burst rip. Regarding options, I use mostly default. But examine them all to see if you want something different. They are all mostly self explanatory.
  5. #5
    Join Date
    Mar 2022
    Hi
    well good point , i will use the secure ripping , might you post a screenshot of your settings?
    because dbpoweramp doesn't detected c2 on mac but it does detect under windows , same drive by the way
    thanks , appreciate your help
  6. #6
    Join Date
    Nov 2007
    Location
    Florida, USA
    Hi
    I am away from my computer until Saturday. I will try to post then. Which settings are you talking about? Secure ripping? Metadata? Or ?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
