Album Art Max Resolution Upper Limit Setting
  • warhorus
    • Sep 2022
    Is there any way to disable or manually set the max resolution to something higher that 1400x1400 in PerfectTUNES Album Art? I'd like to take advantage of higher resolution images when I find them. As it stands when I go to fix an album with missing art and I see that there's a decent image of a higher resolution, I have to track it down and update the files manually which can be cumbersome.
    • 43898
    Re: Album Art Max Resolution Upper Limit Setting
    In the options page, you can type which ever maximum size you like, such as:
    3000 x 3000
