Is AccurateRip 100% accurate?
  • bimsie20
    • Jun 2022
    A little while ago I ordered a Japanese CD called "Kyogen" form Ado.
    I also heard about CD ripping, so I ripped it to FLAC and it sad "ripped Accurate".
    But when I compared the difference between the FLAC-file (16bit) downloaded from Qobuz to the ripped FLAC-file (16bit), it did not sound the same.
    The ripped file was less enjoyable to listen to, and I didn't hear as much bass.
    So my question is: "Does AccurateRip realy mean 100% accurate?"
    If YES: than could it be the quality of the CD production?
    If NO: is it my CD drive that is bad?
    • 43896
    Re: Is AccurateRip 100% accurate?
    You should try playing the CD vs the download, Accurate rip will only rip what is on the CD. If you have a different release, or recording...
