Issue using powershell to run coreconverter.exe for flac to mp3 conversion
  • tadakan
    • May 2022
    Hello,
    I'm getting an error when trying to script a conversion from flac to mp3 in powershell, however, running the same command in the window command line works successfully.
    I am cding to my Program Files\dbpoweramp directory and running ".\CoreConverter.exe -infile="C:\Transcodes\Test\Test.flac" -outfile="C:\Transcodes\Test\Test.mp3" -convert_to="mp3 (LAME)" -V0"
    In powershell it returns "Error: Unable to load encoder 'mp3'. [dBCoreConverter::dBCoreConverter]" but in the regular windows command line it runs the conversion successfully.
    I'm guessing this may be some sort of environment issue that I'm not understanding. I get the same behavior when I start powershell "as administrator."
    Any suggestions on how to proceed with troubleshooting this?
    • 43923
    Re: Issue using powershell to run coreconverter.exe for flac to mp3 conversion
    Start core converter using the full path to it, not .\
