Results 1 to 3 of 3
Thread: Nimbie 5m usb 3.0 cable does not work.
  1. #1
    Join Date
    Feb 2021
    I use Nimbie usb plus and batch ripper. However, the original blue usb 3.0 cable was short, so I replaced it with a 5m usb 3.0 cable. Then nimbie was not loaded in the batch ripper configuration, and it was the same in the batch ripper. The 5-meter cable was the problem, so even if I change it to another 5-meter cable, the result is the same. Is it possible to operate with this 5m usb 3.0 cable? Can't it be loaded unless it's the short cable that was originally provided? If thers`s a compatible 5m usb 3.0 cable, I would appreciate it if you could introduce it to me.
  2. #2
    Join Date
    Apr 2002
    Re: Nimbie 5m usb 3.0 cable does not work.
    It is unlikely it would work with such a long cable usb3.0 has a 2m cable length limit.
  3. #3
    Join Date
    Feb 2021
    I solved it. I used an active repeat cable of 5.0m and it loaded the niembie driver.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
