Edit ID-Tag Problem
  • Bjorn43
    • Sep 2018
    • 8
    Edit ID-Tag Problem
    I have used the dBpoweramp for a couple of years and like it very much. I have problem related to a music file. I ripped an entire CD and all tracks except one does not show me the ID-Tag when I right click on the file. All other files are OK. This happens with a few other rips as well. I have uninstalled the dBpoweramp, rebooted my computer and then reinstalled the program. That did not help. I then went to Advanced settings and unchecked all the Explorer Integration settings and rebooted again. I then went back and checkmarked all the Explorer Integration settings again but problem remains.
    I have no clue as to what I can do to solve this problem.
    • 43898
    Re: Edit ID-Tag Problem
    If you right click >> Edit ID Tags
    and there are none, then the file has no ID Tags.
    • Bjorn43
      • Sep 2018
      • 8
      As I stated I can not Right click on the Edit Tag because it is not available!
        • 43898
        It is likely the files were interrupted when ripping, CD ripper normally rips to ._ files then at the end of ripping the extensions are renamed to .flac (if using flac).
        Delete that disc and re-rip.
          • 4015
          Also, check your audio files are not corrupted by running dBpoweramp Music Converter > Test Conversion.
          What file format are these files?
