CD Ripper 17.4 just hangs on rip. CD-ROM drive doesn't start read.
Re: CD Ripper 17.4 just hangs on rip. CD-ROM drive doesn't start read.
You cannot not have a title, as that is used to create each filename. -
I mean I blanked out the pic of what I was ripping but all the fields and metadata are populated. I click rip and it just sits there. The drive doesn't engage. Been using on the same comp for a decade. The drive works fine though.Comment
Change the encoder to 'Test Conversion', does it rip the cd then?Comment
Look at the file names and ensure the locations where the tracks are to be written exists and has write permissionsComment
I cleared the HKCU keys. If I select just FLAC for example, ripping works. But multi-encoder does not work.Last edited by Arkiados; 11-02-2021, 04:23 PM.Comment
Remove your two encoders and re-add them, buy default naming is set to match CD Rippers naming which is:
[MAXLENGTH]80,[IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][][]\[MAXLENGTH]80,[album][]\[MAXLENGTH]80,[track] [artist] - [title][]
if you need to change the base location at the top of the naming page (choose Output To >> edit dynamic naming).Comment
Remove and re-add encoders and it now just doesn't rip like before.Attached FilesComment
What security software do you have?Comment
Try safemode with networking, ensure you are ripping to a local drive.
Find out how to boot into safe mode in Windows from Settings, the sign-in screen, and a black or blank screen.
Does that work. Also only have 1 encoder in multi-encoder, a wave encoder.Comment
