Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: How do I Map network Drive?
  1. #1
    Tombei's Avatar
    Join Date
    Jun 2011
    Question How do I Map network Drive?
    Hi, I have recently had to change my password and login details to my Synology NAS. When I now try to map the network drive through the Synology Assistant I get a pop-up (Windows Security)asking me to enter my network credentials. Now everything is currently working OK (meaning I'm connected to the network and everything works OK) BUT my wifi network details do not let me connect to the drive. I'm pretty sure it's not a network password issue as such but maybe something to do with how the initial mapping was initiated but now the changes have screwed something up. Any suggestions on how to rectify will be greatly appreciated!
  2. #2
    Join Date
    Apr 2002
    Re: How do I Map network Drive?
    The synology is wired to the network so it requires no passwords.
    Look for the NAS under Windows file explorer >> Network
    It should appear under the 'computer' section
  3. #3
    Tombei's Avatar
    Join Date
    Jun 2011
    Thanks for the reply Spoon. Yes I can see the drive on Windows file explorer but it has a big red cross on it and I can't connect.
  4. #4
    Join Date
    Feb 2014
    Disconnect the network drive within the file explorer and try to reconnect it to assign a new drive letter. You will be asked for a account name and password, if the shared folder is not public and needs privileges.
    Tombei's Avatar
    Join Date
    Jun 2011
    Quote Originally Posted by Dat Ei View Post
    Thanks for the suggestion. I'll give it a try and let you know how I go. Cheers.
  6. #6
    Tombei's Avatar
    Join Date
    Jun 2011
    I tried this but no success. When I enter the Network Credentials for Windows Security I get an error message from Synology Assistant stating "Failed to connect to the server. Make sure you are connected to the server and you have entered the correct user name and password. (Error code: 0).
  7. #7
    Join Date
    Feb 2014
    Then you have to check the shares on the Synology. Log into the Synology, check that SMB/Samba is enabled, check the share and the accounts, passwords and privileges for the share.
    Tombei's Avatar
    Join Date
    Jun 2011
    Hi there, I have double checked all settings and everything is as should be. This is getting extremely frustrating, so I really appreciate the suggestions.
  9. #9
    Join Date
    Feb 2014
    Did you try to map the drive with the Synology Assistant only or the standard windows method too? Can you access the drive with the file explorer?
    Tombei's Avatar
    Join Date
    Jun 2011
    I originally tried to map the drive through Synology Assistant (so I could rip some CD's to the NAS) that's when it went pear shaped. I can't seem to map the network drive through windows (it keeps asking me to enter the network credentials (such as the user name and password) but it says my password is incorrect, however I am using the network password as I have checked the router settings. Also I can connect to the NAS through Synology Assistant and I can see all my audio files there! I just can't play any music through Sonos or rip files to the NAS.
  11. #11
    Join Date
    Feb 2014
    Have you enabled SMB / Samba on the NAS?
    Tombei's Avatar
    Join Date
    Jun 2011
    Yes the setting was already enabled.
  13. #13
    Join Date
    Feb 2014
    Can you define a share with RW privileges to public for a test? Can you access this share?
    Tombei's Avatar
    Join Date
    Jun 2011
    Do you mean like set up a Guest account and try and map to that?
  15. #15
    Join Date
    Feb 2014
    Set up a new shared folder, assign RW privileges to that shared folder for public (no account, no password). Try to access the shared folder with the file explorer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
