Results 1 to 9 of 9
Thread: Tag problems
  1. #1
    Join Date
    Jun 2021
    Tag problems
    My only complaint about your excellent ripping program is the difficulty of knowing in what order information on the tags to a ripped CD will appear on ones hard drive. I am never sure what item will show first, and I also don't understand why sometimes extra folders within folders will get created, so that navigating to find a particular piece can take a couple of more steps than strictly necessary, and knowing exactly what is in a particular file is difficult. I wonder if there's a post-facto fix for this, and I word urge you to provide clearer instructions for file labeling to new users of the program.
  2. #2
    Join Date
    Apr 2002
    Re: Tag problems
    File order is based on the filename, alphabetic, unless you write to a USB flash disk and as used in some cars (which is based on order written).
  3. #3
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Tag problems
    Quote Originally Posted by Arslonga View Post
    Nothing is broken so there is nothing to fix. You probably need to read the help on Path and Naming.
  4. #4
    Join Date
    Apr 2015
    Location
    England
    Re: Tag problems
    Yes, my Pioneer car unit does this reading from a USB stick: this is (obviously) the only time I see a random order.
    Can anyone suggest a way around this please?
  5. #5
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: Tag problems
    Naming and folder creation is not random, but based on how you have setup your path and dynamic naming string. See:
    https://www.dbpoweramp.com/help/dmc/Naming.htm
  6. #6
    Join Date
    Apr 2002
    Re: Tag problems
    TuneFUSION has a special write option which orders them correctly on a FAT32 formatted stick.
  7. #7
    Join Date
    Apr 2015
    Location
    England
    Re: Tag problems
    Thanks Spoon.
    Does TuneFUSION integrate with Batch Converter? If not that write option would make an excellent DSP (please!!).
  8. #8
    Join Date
    Apr 2002
    Re: Tag problems
    It is not possible to do it as a DSP effect, TUNEFusion is stand alone, it has the abilities of batch converter, but better for the task.
  9. #9
    Join Date
    Apr 2015
    Location
    England
    Re: Tag problems
    TuneFUSION purchased and installed, will direct questions in that thread.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
