Results 1 to 5 of 5
Thread: Settings Override (Control Point Specific) - Known Control Point List
  1. #1
    Join Date
    Jul 2012
    Smile Settings Override (Control Point Specific) - Known Control Point List
    Is there a way to clear this list to help identify latest connections/versions?
    Ultimately I want to customise individual control points' handling of artwork resizing, for example my Cyrus Stream remote has a limit while BubbleUpnp does not.
    Any tips on the scripts to achieve this too would be great.
    Cheers
  2. #2
    Join Date
    Apr 2002
    Re: Settings Override (Control Point Specific) - Known Control Point List
    Where Asset writes its configuration files (for Linux look at the help as each platform is different) there is a file:
    KnownControlPoints.txt
    Delete it.
  3. #3
    Join Date
    Jul 2012
    Brilliant thanks that worked.
    Is there a reference for the various overrides/scripts available?
  4. #4
    Join Date
    Apr 2002
  5. #5
    Join Date
    Jul 2012
    Thank You
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
