Hi, I have one file that has almost silence at the end, but isn't quite silence. Is there a means by which to get rid of that too? Maybe there is some settings adjustment of which I'm not aware. I just signed up. Thank you
On the trim silence page you can set silence as 'any value below', increase the percentage, try 1% if not work then 2%, keep working up, if too high it will trim the actual audio.
