Can't rip "Misty"
    • 4015
    Re: Can't rip "Misty"
    Originally posted by kswanson
    A cleaned up version of Windows 10.
    Sorry, I don't know what you mean by cleaned up. Care to explain?
    • kswanson
      • Dec 2010
      • 49
      It's a non consumer version that is simplified and without most bells and whistles. The actual name escapes me at the moment.
        • 4015
        This makes no sense but I deleted the IP address of my server in DbPA and re entered it.
        So, on your windows 10 desktop running dBpoweramp, exactly where are you entering the IP address?
        • kswanson
          • Dec 2010
          • 49
          I enter the IP address in the Path on DBPA. After I click set it asks me to choose a file and I choose my server.
            • 1748
            You better work with the network name of your server, especially if your DHCP server assigns a dynamic IP to your server.
            • kswanson
              • Dec 2010
              • 49
              #21
              It is assigned a dynamic IP address and I do use the server's network name when asked to chose a file.
                • 4015
                #22
                That's not a good idea.
                On the server, share the destination folder. Then, on your windows 10 desktop pc, either Add a network location OR Map a network drive using the server share. Finally, in CD Ripper use the share name in the path.
                • Oggy
                  • 697
                  #23
                  Completely agree.
                  I've used both methods successfully, originally working out how to map the drive took me longer than everything related to ripping CDs, except trying to adapt my own naming string!
                  There are some brilliant folks on this forum who give their time helping everyone who needs it.
                  • kswanson
                    • Dec 2010
                    • 49
                    #24
                    I wasn't clear. I did add a network location so I was following your instructions. Still had the problem so I deleted DBPA and reloaded it. Problem solved. Somehow the program got corrupted apparently.
