cd issue
This topic is closed.
    • 43891
    Re: cd issue
    Until we have the file we cannot comment. It is likely the file is correct with Album art and your issue is the NAS, if this is the case then there is nothing you can do in CD Ripper.
    If you cannot email the file, upload it to (create a free account):
    Dropbox helps you simplify your workflow. So you can spend more time in your flow.
    And share a link to the file please.
    • sicknote
      • Mar 2021
      • 22
      Re: cd issue
      this programme is not working just ripped cd and put onto my dongle for my car no artwork on it so its not doing what it should be so can someone plesae get back to me to sort out like i said its only started doing this on windows 10
        • 43891
        Re: cd issue
        We cannot begin to help you unless you provide a file for us to look at.
          • 1745
          Re: cd issue
          Sound systems in cars are often limited. The sound system in my car can only show album arts if they do not exceed 800px * 800px. I know other systems that limit not only the size in pixels, but the file size too.
          • Oggy
            • 697
            Re: cd issue
            Absolutely and you beat me to it.
            My Pioneer unit for example only displays the cover art if all three criteria are net.
            The cover must be embedded.
            Max pixel size 600x600 and max file size 250.
            Sicknote, many people have issues displaying covers on car units which are nothing to do with using dBpoweramp and Windows 10.
            I use Windows 10, dBpoweramp and have no issues with artwork being written to a NAS. Spoon is trying to help, but cannot if you do not supply the information he needs.
            • sicknote
              • Mar 2021
              • 22
              #21
              Re: cd issue
              thanks for geetting back to me over this issue sorry i paid for this programeme not worth the money for either prog thanks for your help
              • sicknote
                • Mar 2021
                • 22
                #22
                Re: cd issue
                ok mate ive changed nothing on my prog hes asking me to send files like i explained im not that computer zaffi ive put music on my dongle and on my nas drive no issues before windows 10 so something has changed and its doing my head in can someone speak to me in tems i can understand thanks
                • sicknote
                  • Mar 2021
                  • 22
                  #23
                  Re: cd issue
                  how do you put cd on your nas drive
                  • sicknote
                    • Mar 2021
                    • 22
                    #24
                    Re: cd issue
                    ok mate never had an issue before put cd in copied opened and then sent to my nas drive and dongle
                    • sicknote
                      • Mar 2021
                      • 22
                      #25
                      Re: cd issue
                      ok what format do you copy in never had an issue before but why now not changed any thing
                        • 4015
                        #26
                        Re: cd issue
                        We understand that you haven't changed anything in the Illustrate software, but you have updated the operating system to Windows 10, so many things have changed.
                        Q1. Which OS were you running before the upgrade?
                        Q2. Which version of the Illustrate software are you running?
                        Q3. Have, you read post no. 16 and if so, which part of that post do you not understand?
                        Finally, if you are using Windows 10, you can share the file using OneDrive and then provide Spoon with the link.
                          • 5742
                          #27
                          Re: cd issue
                          And just to be clear, dbpoweramp music converter works perfectly on two different windows 10 machine I use. So it's not that the program no longer works on Windows 10. It does. I do understand that you're having issues, but folks here need more information to help you diagnose the problem.
                          • sicknote
                            • Mar 2021
                            • 22
                            #28
                            Re: cd issue
                            as i have said not very good on computers if some could run me through how to send information so i can start using the prog thanks
                              • 4015
                              #29
                              Re: cd issue
                              Share files and folders in OneDrive
                                • 4015
                                #30
                                Re: cd issue
                                ... and this is a support forum and if you choose not to answer questions asked, then we can't help you.
