Replacement for Tuneup!
  • Nigel55us
    • Mar 2021
    I just purchased PerfectTUNES hoping it would be able to rename and tag my files the way Tuneup used to.
    I am not interested in manually renaming 100k plus files in my iTines library.
    I have tried MusicBrainz Picard, but it's not very good at handling large quantities of files at he same time.
    Does PerfectTunes g=have this future, or have I been dreaming?
    Cheers
    • 5744
    Re: Replacement for Tuneup!
    Do you simply want to rename the files and/or directories based on information already in the metadata tags? If so [ARRANGE AUDIO] dsp (part of dbpoweramp converter) can do that for you.
