Hard Ware Upgrade
  • clubsceneuk2
    • Aug 2017
    • 18
    Hard Ware Upgrade
    Hi. Just upgraded my PC case and due to this I have now had to remove the Blue ray device externally as the new case does not have a slot for it. I have purchased an Inateck UA1001 Adaptor which works a treat with one issue. I can not use a key CD to ensure I have accurate rip. When I try I get an error advising that either the CD key is not the same as the stored device or my CD ripper is not listed.
    I assume its the second one as I'm now using the inateck adaptor so the device shows as the adaptor name.
    Are there any suggestions that i could use to help correct this?
    • 43920
    Re: Hard Ware Upgrade
    Does CD Ripper show the name of your drive correctly?
