Results 1 to 9 of 9
Thread: Normal Audio CD to rip in higher resolution?
  1. #1
    Join Date
    Feb 2015
    Dear All,
    I am quite new and preparing to rip my full CD library.
    From reading in this forum and other support sites, I understand as a general rule, that most (ist not all?) standard Audio CDs are produced in 44.1 kHz / 16 bit.
    Now I am using ROON as Media Player and many different Sonos speakers in the house; Sonos supports since mid of last year also FLAC/ALAC with 24 bit and up to 48 kHz.
    My question is now, does it make sense to convert my CDs in this higher resolution and is this possible at all?
    Thank you and have a good start into the new year,
    Christian
  2. #2
    Join Date
    Dec 2008
    Location
    London, UK
    Re: Normal Audio CD to rip in higher resolution?
    Quote Originally Posted by Apple-Fan View Post
    It IS possible, but makes no sense as you will NOT get higher resolution than the original source i.e. 16-bit, 44.1kHz.
  3. #3
    Join Date
    Feb 2015
    Thank you for the quick reply.
    But then I need to re-ask again: if I will not get any higher resolution as the source can deliver (which is for almost every Audio CDs 44,1, 16-bit), for which reason is is technically possible? is there any use case I am not aware of? Thank you!
  4. #4
    Join Date
    Dec 2008
    Location
    London, UK
    ALL red-book audio CDs (CDDA) are 44.1 kHz, 16-bit.
    It is technically possible to change the bit rate and sampling rate when ripping CDDA in CD Ripper, by using DSPs.
    Users may have a requirement for higher (or lower) resolution audio files, maybe for testing purposes.
  5. #5
    Join Date
    Nov 2007
    Location
    Florida, USA
    To be blunt, it is basically a bit bizarre to rip 16/44.1 CDs to any higher bitrate. It does absolutely nothing other than create larger files. Audio is not changed.
  6. #6
    Join Date
    Jul 2010
    Analog loop.
  7. #7
    Join Date
    Mar 2021
    I'm curious about when I see Hi-Res music vendors (HD Tracks, Pro Studio Masters, etc.) offering albums/songs in AIFF, FLAC, ALAC, etc at 16 bit/44.1kHz, would these be the exact same quality audio files that I can RIP with CD Ripper?
  8. #8
    Join Date
    Nov 2007
    Location
    Florida, USA
    Quote Originally Posted by VBJohn View Post
    Yes!
  9. #9
    Join Date
    Mar 2021
    Cool Re: Normal Audio CD to rip in higher resolution?
    Quote Originally Posted by garym View Post
    Yes!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
