Changed Behavior In Character Mapping
  • husker
    • Dec 2013
    • 62
    I haven't ripped any classical CDs in a long time (prior to R17), and I'm having difficulty now.
    I had extensive character replacements. For example:
    1. I want to remove any comma - I would do a character replacement for , and then nothing
    2. Replace a colon with a space hyphen space
    I have several more examples that don't seem to work now.
    I found the global option for the semicolon - but it will not accept/save a space hyphen space
    The comma deletion just doesn't work at all.
    These worked OK in previous versions - is there a way I can get this functionality back?
    • 43902
    Re: Changed Behavior In Character Mapping
    To remove a comma in CD Ripper >> CD Ripper Options >> Filename Restricted Characters
    Enter , on the left side and * on the right.
    To replace ';' with '; ' that would be in DSP effect 'ID Tag Processing' under Word / Character replacement, however you will stop multi-artist aware programs from working correctly
    • husker
      • Dec 2013
      • 62
      OK, so now the asterisk is a blank space? Does the comma replacement have to be in the main CD Ripper Options, or can it be a DSP effect?
      You typed a semi colon, then a semi colon space. What I need is to replace ': ' with ' - '
      • husker
        • Dec 2013
        • 62
        For example - I need this
        Les Francs-Juges, Op. 3, H. 23d: Overature
        to look like this
        Les Francs-Juges Op. 3 H. 23d - Overature
          • 43902
          Yes you can still do that with the DSP effect.
          • husker
            • Dec 2013
            • 62
            OK, given my example above, can you please tell me how to setup DBPoweramp? What used to work no longer works.
              • 43902
              add ':' to ' - '
              • husker
                • Dec 2013
                • 62
                add ':' to ' - '
                Yes, that is what I've been trying to say. That no longer works - you get an error on file write, and it leaves a misnamed 0 byte file. See screenshots below:
ID:	294381Click image for larger version
ID:	294382Click image for larger version
                  • 43902
                  You would have to refresh the disc so the metadata is processed again, I can see you still have ':' in the filename which is an illegal character.
                  • husker
                    • Dec 2013
                    • 62
                    Please understand - that is the problem! DBPoweramp is not processing the DSP properly. I have the ':' replaced with ' - ' and DBPoweramp is not processing that correctly. I provided the screenshots in the previous post.
                    • husker
                      • Dec 2013
                      • 62
                      Spoon, can you please help me with this problem.
                        • 43902
                        It is working for me, try this:
                        Load any CD into CD Ripper, add the DSP effect 'ID Tag Processing' on Word / Character replacement add:
                        (in first then 2nd box, ensure no blank lines after).
                        Then right click on where it says 'Rip Status' above the track listing, enable the 'Filename' column, so you can see the output filename.
                        Next change the album title, enter:
                        Album: Test
                        You should see instantly the filenames change to show Album - Test
                        Try the above, does it work like that for you?
                        • husker
                          • Dec 2013
                          • 62
                          Album: Test
                          I followed your instructions. I enabled the Filename column, ensured that the DSP is correct (screenshot attached), and changed the Album title. What is interesting is that that filename column never changes. It stays blank no matter what change I make at the top (album, artist, year, anything). Screenshot is also attached. So, I guess it is never reading the DSP.
ID:	294388Click image for larger version
                            • 43902
                            What naming string do you have? (file naming in the lower left corner)
                            What happens also if you remove the DSP effect?
                            • husker
                              • Dec 2013
                              • 62
                              I setup a brand new profile for testing, so the naming is simple: [Composer]\[album]\FLAC\[track] - [title]
                              Removing the DSP has no effect - same ripping error, and the filename column does not populate.
