Problem installing Asset UPnP
  • budski
    • Dec 2020
    I have just purchased Asset UPnP following a successful trial. I am running it on a Raspberry Pi 4 and the trial software worked well.
    When I follow the installation instructions and insert the Order Number (XXXXXXXXXX below) into the script I get the following message:
    wget http://secure.dbpoweramp.com/downloa...num=XXXXXXXXXX -O asset.tar.gz
    --2020-12-19 15:52:26-- http://secure.dbpoweramp.com/downloa...num=XXXXXXXXXX
    Resolving secure.dbpoweramp.com (secure.dbpoweramp.com)... 89.238.133.252
    Connecting to secure.dbpoweramp.com (secure.dbpoweramp.com)|89.238.133.252|:80... connected.
    HTTP request sent, awaiting response... 409 Download locked try again in 3 hours
    2020-12-19 15:52:28 ERROR 409: Download locked try again in 3 hours.
    Can you help?
    • 43898
    Re: Problem installing Asset UPnP
    We have updated the instructions,
    Downloading Asset, registered version, this must be done to a PC using the registration link in your email receipt, or the link presented after purchase. After downloading transfer the install to your device (perhaps by USB flash drive)
    • stevesound
      • Aug 2018
      • 9
      Hi, Just purchased a full version of Asset, I can only open the configuration page but not Asset, also I want to install it on my Qnap 251+ 2 but I can not find the App in the Qnap store can you give some advice?
      Steve
        • 43898
        You have downloaded the .qpkg file (which is the QNAP install) then installed on the QNAP?
        Where are you seeing the Configuration page? on your Windows PC?
        • stevesound
          • Aug 2018
          • 9
          Hi Spoon, I have a trial version on my Qnap which works fine, I purchased a version for windows 10 which I wanted to open in Kazoo and hopefully in my Qnap, after installing the registered version I can only find the configuration page and the help page on my PC but no Asset, in my Qnap the trial version opens the Asset window straight away, also I can see and open the trial Asset in Konfig and Kazoo I assume I have done something wrong, can I convert my Trial version to my registered version?
          Thanks Steve
            • 43898
            We only offer a all platform purchase now, if you look on your Asset download page you should see a download for the QNAP. Uninstall the trial, uninstall the Windows 10 version, and install the registered version on the qnap.
            • stevesound
              • Aug 2018
              • 9
              Hi Spoon, Thanks for the help all working fine now, lucky it is a platform purchase as I selected the wrong file.
              Steve
